I am using a C6 sensor and having problems with image acquisition because of “Multi part”, basically I am trying to change the parameter “GevSCCFGMultiPart” to false to solve this problem but I can’t find how to do that (the NodeMap value is read-only.
Thank you!
I am having a problem understanding the whole “Node” system, how do I change values?
If I want to change the “GevSCCFGMultiPart” to false how do I do that?
I think I have managed to change the value but it seems ridiculous that I had to Cast the Node to BooleanNode in order to change the Value.
Sadly after changing the value to false and activating the grab the black strip image doesn’t change.
The stream is open and receiving frames but they are fully black.
The Image I see in the wpf display controller :
There is also a recommendation in the document for working with C6 cameras that suggests to use the cxSolutionPackage (https://www.at-sensors.com/product-support/downloads/) from the supplier for setting up the camera in the first place. The GenICam-Browser is very usefull to setup any kind of areascan or linescan cameras, but the C6 is very specific as there are multiple image modes.
After setting up your camera setup, it is easy to switch to CVB for your application using the MultiPart Support in CVB. See the MultiPart with a C6 here: https://forum.commonvisionblox.com/t/switching-from-automation-technology-c5-to-c6-cameras-in-cvb/1868/2
