I have a small wrapper of your CVB api written in c++ meant to be called from a C# application in Unity.
This unity project uses a webrtc binary which causes the error below.
This problem does not occur with the M92 webrtc release and does with M107
I’m wondering if anyone else has had this issue or has some clue?
I have also opened an issue with the Unity plugin: https://github.com/Unity-Technologies/com.unity.webrtc/issues/878
[CVBLib]: Discovering devices...
Caught fatal signal - signo:11 code:1 errno:0 addr:0x382d5e
Obtained 27 stack frames.
#0 0x007f6d35f9c420 in funlockfile
#1 0x007f6d37928441 in block_merge_next
#2 0x007f6d37928313 in tlsf_free
#3 0x007f6d36b4c301 in DynamicHeapAllocator::Deallocate(void*)
#4 0x007f6d36b52f1e in DualThreadAllocator<DynamicHeapAllocator>::TryDeallocate(void*)
#5 0x007f6d36b4d12c in MemoryManager::Deallocate(void*, MemLabelId, char const*, int)
#6 0x007f6ad6f0b6fc in std::istreambuf_iterator<char, std::char_traits<char> >::equal(std::istreambuf_iterator<char, std::char_traits<char> > const&) const
#7 0x007f6ad6efdbc8 in DevOpenDataStream
#8 0x007f6ad6efe973 in GCInitLib
#9 0x007f6c97cdccfe in std::__cxx11::_List_base<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >::_M_clear()
#10 0x007f6c97cb765f in std::pair<std::_Rb_tree_iterator<unsigned long>, bool> std::_Rb_tree<unsigned long, unsigned long, std::_Identity<unsigned long>, std::less<unsigned long>, std::allocator<unsigned long> >::_M_insert_unique<unsigned long const&>(unsigned long const&)
#11 0x007f6c97cb8708 in std::pair<std::_Rb_tree_iterator<unsigned long>, bool> std::_Rb_tree<unsigned long, unsigned long, std::_Identity<unsigned long>, std::less<unsigned long>, std::allocator<unsigned long> >::_M_insert_unique<unsigned long const&>(unsigned long const&)
#12 0x007f6c97c86d54 in CVFFactoryCreate
#13 0x007f6c9dbc4887 in std::_Rb_tree_node<std::pair<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > > >* std::_Rb_tree<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> >, std::pair<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > >, std::_Select1st<std::pair<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > > >, std::less<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > >, std::allocator<std::pair<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > > > >::_M_copy<std::_Rb_tree<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> >, std::pair<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > >, std::_Select1st<std::pair<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > > >, std::less<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > >, std::allocator<std::pair<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > > > >::_Alloc_node>(std::_Rb_tree_node<std::pair<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > > > const*, std::_Rb_tree_node_base*, std::_Rb_tree<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> >, std::pair<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > >, std::_Select1st<std::pair<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > > >, std::less<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > >, std::allocator<std::pair<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > > > >::_Alloc_node&)
#14 0x007f6c9dbc598a in std::_Rb_tree_node<std::pair<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > > >* std::_Rb_tree<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> >, std::pair<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > >, std::_Select1st<std::pair<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > > >, std::less<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > >, std::allocator<std::pair<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > > > >::_M_copy<std::_Rb_tree<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> >, std::pair<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > >, std::_Select1st<std::pair<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > > >, std::less<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > >, std::allocator<std::pair<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > > > >::_Alloc_node>(std::_Rb_tree_node<std::pair<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > > > const*, std::_Rb_tree_node_base*, std::_Rb_tree<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> >, std::pair<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > >, std::_Select1st<std::pair<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > > >, std::less<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > >, std::allocator<std::pair<std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const, std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > > > >::_Alloc_node&)
#15 0x007f6c9dbae33c in DODiscoverW
#16 0x007f6c9dbae615 in DODiscover
#17 0x007f6c9dd83fdf in std::vector<Cvb::V_1_6::Driver::DiscoveryInformation, std::allocator<Cvb::V_1_6::Driver::DiscoveryInformation> > Cvb::V_1_6::DeviceFactory::Discover<long, std::ratio<1l, 1000l> >(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, Cvb::V_1_6::Driver::DiscoverFlags, std::chrono::duration<long, std::ratio<1l, 1000l> > const&)
#18 0x007f6c9dd6c1a0 in GetDevices
#19 0x00000041410673 in (wrapper managed-to-native) Ocellus.Gigecam.Cvb.CVBLibWrapper:GetDevices (Ocellus.Gigecam.Cvb.DiscoveryInformation[]&,int&)
#20 0x00000041410384 in Ocellus.Gigecam.Discovery.DiscoveryHelperLinux:GetDevices ()
#21 0x00000041410078 in Ocellus.Gigecam.Discovery.DiscoveryHelper:GetDevice (string,string&,string&)
#22 0x0000004140cd3f in System.Runtime.CompilerServices.AsyncMethodBuilderCore/MoveNextRunner:InvokeMoveNext (object)
#23 0x000000411d0214 in System.Threading.ExecutionContext:Run (System.Threading.ExecutionContext,System.Threading.ContextCallback,object,bool)
#24 0x0000004140ca13 in System.Threading.Tasks.AwaitTaskContinuation:RunOrScheduleAction (System.Action,bool,System.Threading.Tasks.Task&)
#25 0x0000004132aa50 in System.Threading.Tasks.Task:FinishContinuations ()
#26 0x0000004132a8f0 in System.Threading.Tasks.Task:FinishStageThree ()
