BGR detection at runtime
In one of the examples, the bytes from an image are copied to a bitmap. The way of copying depends on the pixel format of the image (RGB or BGR). In the example, this is done as follows:
#if BGR
              *(pDst++) = *pSrc[2];
              *(pDst++) = *pSrc[1];
              *(pDst++) = *pSrc[0];
#else
#endif
Is there a check for this which can be executed at runtime?
do you want to detect whether the memory buffer layout of a :cvb: Image is BGR or do you want to create a BGR bitmap (like e.g. a System.Drawing.Bitmap)?
The latter is simplest: you just need to reference the Stemmer.Cvb.Extensions.dll which adds an extension method to :cvb: Image objects: .ToBitmap(). This produces a BGR8 bitmap:
Image cvbImage = ...;
System.Drawing.Bitmap bitmap = cvbImage.ToBitmap()
To determine whether the Image memory buffer layout is BGR, you need to check the pointers and DataType:
static class ImageExtensions
  public static bool IsBgr8(this Image image)
    if (image == null)
      throw new ArgumentNullException(nameof(image));
    if (image.Planes.Any(plane => plane.DataType != DataTypes.Int8BppUnsigned))
      return false; // every plane must be of byte type
    if (!TryGetLinearAccessData(image, out var planeData))
      return false; // BGR image must be linear
    if (planeData.Length != 3)
      return false; // B-G-R planes
    var basePtrs = planeData
      .Select(data => data.BasePtr.ToInt64())
      .ToArray();
    // cvb's plane #0 ist red, #1 green and #2 blue
    return (basePtrs[2] == (basePtrs[1] - 1))
      &&   (basePtrs[1] == (basePtrs[0] - 1));
  private static bool TryGetLinearAccessData(Image image, out LinearAccessData[] planeData)
    Debug.Assert(image != null);
    planeData = new LinearAccessData[image.Planes.Count];
    for (int planeIndex = 0; planeIndex < planeData.Length; planeIndex++)
      var plane = image.Planes[planeIndex];
      if (!plane.TryGetLinearAccess(out planeData[planeIndex]))
        return false;
    return true;
I need to determine the memory layout. :slight_smile:
