The CVB.Net API (see also this post) is a new object oriented wrapper for the
SDK. It has been designed to harmoniusly integrate into the .Net API and makes leveraging the abilities of
for complex applications written in one of the .Net/CLR languages easier than the classic C-like API.
CVB.Net has been built versus the .Net 4.0 runtime and therefore requires Visual Studio 2010 or higher to work with. For GUI integration, CVB.Net offers two options:
- Windows Forms applications may use the component
Stemmer.Cvb.Forms.Controls.Displayon their forms. This component is based on the CVCDisp.dll of
and integrates all the features that the CVDisplay.ocx offers, including integration of *.opi plug ins. - WPF applications can use the
Stemmer.Cvb.Wpf.Controls.Displaycontrol which is an IL-implemented display derived fromSystem.Windows.Controls.ItemsControl, capable of displaying anySystem.Windows.UIElement-derived object as a non-destructive overlay (a few “standard” overlays may be found in the namespaceStemmer.Cvb.Wpf.Overlays).
As long as no platform-specific elements were used, CVB.Net should also be usable on any platform for which
and a .Net Core 2.0 compliant runtime are available.
Caveats
- Make sure the
CVB.Netpreview you installed matches the architecture of your
installation. While in principle all CVB.NetDLLs except one (Stemmer.Cvb.Aux.dll) have been implemented as IL DLLs, the fact that there is currently no hybrid
installer (i.e. an installer that simultaneously installs the 32 and the 64 bit build on a 64 bit operating system) makes it necessary to stick with the architecture that has been installed on your system. This specifically means that with a 64 bit installation one cannot expect an x86 build to run and vice versa and that Any CPU builds should not be used when working with a 32 bit installation on a 64 bit operating system.
(It is, however, possible to build an AnyCPU IL *.exe and then deploy it to either a 64 bit OS with the 64 bit build installed or a 32 bit OS with the 32 bit build installed) - To make
Stemmer.Cvb.Forms.Controls.Displaywork in the Visual Studio Forms designer even if
has been installed for 64 bit, the 64 bit installer of the CVB.Netpreview installs a few additional DLLs into C:\Windows\SysWOW64 and the 32 bit build of Stemmer.Cvb.Aux.dll in the Global Assembly Cache that allow Visual Studio the instantiation of a 32 bitStemmer.Cvb.Forms.Controls.Displayin the designer.
