I have an application where I need to start and stop acquisition frequently to set parameters on the camera which can be set while the camera is acquiring. For instance, saving and loading usersets.
The code I use for starting and stopping is below, together with the code that is running in a separate thread waiting for images to be available.
I frequently end up with the using
var streamImage = _genTlStream.WaitFor(_timeout);
throwing an exception
Acquisition:Acquisition Exception System.OperationCanceledException: GEVTL.cti▸FD::MAC->00-15-17-BB-5F-15▸::ID->00-0C-DF-0A-5C-A0::192.168.3.1 acquisition error.
—> Stemmer.Cvb.CvbException (0x80000014): GEVTL.cti▸FD::MAC->00-15-17-BB-5F-15▸::ID->00-0C-DF-0A-5C-A0::192.168.3.1 acquisition error.
— End of inner exception stack trace —
at Stemmer.Cvb.Driver.CompositeStreamBase.ThrowOnNonOkWaitStatus(WaitStatus status, String debugLocator)
at Stemmer.Cvb.Driver.ImageStream.WaitFor(UsTimeSpan timeout)
at Vim.Cvb.Acquisition.Acquisition.WaitProcessor() in C:\Projects\Calibre\Libraries\Vim\Cvb\Acquisition\Acquisition.cs:line 382
Inner Exception GEVTL.cti▸FD::MAC->00-15-17-BB-5F-15▸::ID->00-0C-DF-0A-5C-A0::192.168.3.1 acquisition error.
This occurs despite the stop operation being successful and the start being OK and status being reported as started.
Once this exception is seen I have to restart the application, not just acquisition.
Can you suggest what I may be doing wrong?
public void Grab(bool live)
if (!MasterEnable || _device == null)
return;
if (live)
if (IsAcquiring) return;
Si.Logger.LogMessage("Go Live " + Name);
TotalFrameCount = 0;
if (_genTlStream != null)
_genTlStream.Start();
_vinStream?.Start();
IsAcquiring = true;
Si.Logger.LogMessage("Go Stop " + Name);
_genTlStream.Abort();
_vinStream?.Abort();
Si.Logger.LogMessage(Name + " Acquisition State " + _genTlStream.AcquisitionState);
IsAcquiring = false;
catch (Exception e)
Trace.WriteLine(Name + ":Exception starting or stopping acquisition " + e);
And now the Wait Processor thread…
protected override bool WaitProcessor()
var result = false;
if (_device != null && MasterEnable && IsOnline && IsAcquiring)
using var streamImage = _genTlStream.WaitFor(_timeout);
CurrentImage?.Dispose();
CurrentImage = streamImage.Copy();
result = true; // We have a valid frame
else if (_vinStream != null)
using var streamImage = _vinStream.WaitFor(_timeout);
catch (TimeoutException)
// Timeout so ignore
catch (Exception e)
Trace.WriteLine("Acquisition:" + Name + " Exception " + e+"\nInner Exception "+e.InnerException?.Message );
Thread.Sleep(100);
return result;
