Hi, i managed to get it to work but i had to change the exposure time variable to a string and use the from_string function, i couldn’t get the value function to work. The code below works as intended though if anyone ever wants to use it
import os
import cvb
with cvb.DeviceFactory.open(os.path.join(cvb.install_path(), "drivers", "GenICam.vin"), port=0) as device:
#opens the camera
stream = device.stream
stream.start()
#starts streaming
device_node_map = device.node_maps["Device"]
#calls the node map
for i in range(10):
exposure=(i+1)*10000
val = str(exposure)
#change exposure to a string and define variable
device_node_map["ExposureTime"].from_string(val)
#this changes the exposure time to whatever value val has
img, status = stream.wait()
#waits till next image is ready and takes it
if status == cvb.WaitStatus.Ok:
print("Acquired image: " + str(i))
img.save("C:\\Users\\TechHP1\\Pictures\\newattempt" + str(i) + ".jpg")
stream.stop()
