Separate the R, G, B channels of RGB images into grayscale images. How should I operate?
I want to separate the R, G, B channels of RGB images into three grayscale images. How should I operate?
You could do it like this:
var planeImages = image.Planes
                       .Select(plane => plane.Map())
                       .ToArray();
This doesn’t actually create new Images, but views on the existing image (we call these views MappedImages). Thus this operation is very fast and doesn’t occupy a lot of space. If you want actual copies you can add
                       .Select(image => image.Clone())
before the .ToArray() call.
