Hi there
I have a problem with a 3d camera:
Vendor: LMI
Model: Gocator 2420
Version: 5.2.18.11
I am using Python and Pycharm and the latest CVb software. After setting the number of buffers to 3, or 10 or 100 or 1000 after the last buffer image (if buffer size = 3, at image 4) i get (i have removed a try catch to find the error):
File “C:/Users/User/PycharmProjects/base-valve/base_valve_GUI.py”, line 816, in run
np_array3D = cvb.as_array(image3D)
File “C:\Users\User\AppData\Local\conda\conda\envs\base-valve\lib\site-packages\cvb_ *init* _.py”, line 281, in as_array
if not image.plane_data_types_identical:
RuntimeError: failed to extract type - resource might be gone
I am using two cameras (the other one a Jai GO-5000M-PGE, no problem with it at any buffer size).
I have optimized the network card setting as per instructions to maximize performance on both cards. The 3D camera is using the GenTl protocol.
the relevant code snippet is:
image3D, status3D = self.stream3D.wait()
np_array3D = cvb.as_array(image3D, copy=False)
np_array_3D = np_array3D[:, :, 0] # height map
The status3D is always good : 0
Thank you for your help,
GTG
