My camera Teledyne Linea is blocked after a new power up.
With Genicam Browser, i have the following issue :
Failed to open device due to std::exception: cvFactoryXX::Interface::OpenDevice - Unable to open Device - with error code: -1001
Is is possible to write a registry in the camera to resolve this issue ?
Hi @dta
This is only a general error that the camera cannot be opened.
We need more information to help you with that.
If the camera is not green it is clear that it cannot be opened and you have to find out why it is not green. e.g. blocked by another application or service.
If it is green and you still get the error we can use the CVB Log GUI to see if we get more information out of it. To get as much information as possible you can configure the LogGUI with default module and level debug.
Attention: For everyone who is reading this. Using this log setup will create a lot of log output if the camera can be opened and a stream is started. Then you would need to log only relevant modules with a reasonable log level.
