Image capturing (Both RGB and IR) with CVB and GiGE camera
@usernv Thank you for your reply.
# CVBpy Example Script
# 1. Discover all devices.
# 2. Load the first device found.
# 3. Acquire images.
discover = cvb.DeviceFactory.discover_from_root(cvb.DiscoverFlags.IgnoreVins)
device = cvb.DeviceFactory.open(discover[0].access_token, cvb.AcquisitionStack.GenTL)
stream_RGB = device.stream(cvb.ImageStream, 0)
stream_IR = device.stream(cvb.ImageStream, 1)
print(stream_RGB)
print(stream_IR)
stream_RGB.start()
stream_IR.start()
for i in range(10):
    image, status, node = stream_RGB.wait()
    image1, status1, node1 = stream_IR.wait()
        print("Acquired image: " + str(i))
stream_RGB.abort()
stream_IR.abort()
I am getting the error:
<cvb.ImageStream object at 0x7f77faa21120>
  File "test_2_streams.py", line 22, in <module>
    stream_IR.start()
RuntimeError: Acquisition is already started.
It seems that stream_RGB and stream_IR both are the same streams. Is it?
@redhat thank you for the test! We are currently looking into the issue and get back to you when the problem is resolved.
@redhat, I sent you the updated Python bindings which should work now. They will also be part of CVB 13.04.001. Many thanks for reporting the bug! :slight_smile:
