Hello CVB .(VC++)
I follow the “Common Vision Blox Manual Hello CVB VC++/MFC” section.
When I run to m_cvImg.GetImage() in the code, I got a error “非選擇性的參數”.
I also develop .Net Version, It’s ok.
I don’t know how to fix it. Is OCX Control issue ?
Welcome @fluber,
can you translate the error? The automatic translation does not really make sense…
Did you copy our wrappers over the generated ones? Do you compile with the corresponding platform? X64 if :cvb: 64 Bit is installed, for example.
