Disconnected camera corrupts the related C# object
I’m developing a C# .NET 10 project using the Teledyne Dalsa Nano 5G M2450 camera.
The camera is directly connected to a 2.5GB NIC of the PC. It’s a 100Hz auto triggered transferring about 95MB/s of data image. The NIC settings are optimized by following your guide.
The frames capture uses the siNetFilter GigE Vision Driver.
C# dll I use are provided by your CVB v15.00.004 SDK (previously tested with last v14 but my issue is the same).
I followed your code examples to implement my app and it works as expected:
Device? device;
device = DeviceFactory.Open(DeviceFactory.Discover().FirstOrDefault());
device.ConnectionStateChanged += ConnectionStateChanged;
loop {
using var image = _device!.Stream.WaitFor(_streamWaitTimeout, out var status);
But sometimes the connection fails and come back but it corrupts the device object and I can’t recover as your examples suggest. Actions to abort/stop/restart the stream leads to a stemmer exception. I observe the same behavior when I disconnect the Ethernet cable and reconnect if.
The only workaround I found is to try to dispose the objet (sometimes it gets stuck indefinitely in this action) and instantiate a new one. But it’s painful because it take a while to recover and is not reliable.
There are some posts already discussing a similar problem but the fix doesn’t work for me or the discussion ended without a solution.
I’m bit confused on what I’m supposed to implement to handle connection state change and what I actually encounter.
Hello Michael,
could you show the exact code that you run when the ConnectionState changes back to Connected?
Cheers,
Tim
Here is the connection Event code:
private void ConnectionStateChanged(object? sender, ConnectionStateChangeEventArgs e)
	if (e.NewState == ConnectionState.Connected)
		TriggerStartStream();
		Log.Debug($"{_sourceDevicePosition} camera event: reconnected");
		TriggerStopStream();
		StatusMonitor.Update(this, _codes.Disconnected, _sourceDevicePosition, true);
		Log.Debug($"{_sourceDevicePosition} camera event: disconnected");
When disconnected, TriggerStopStream() triggers a background task that processes this code:
private void DoStopStream()
	_grab = false;
	var device = _device;
	if (device?.Stream.IsRunning != true) { return; }
	Log.Debug($"{_sourceDevicePosition} camera: stopping acquisition");
		device.Stream.Stop();
	catch (Exception ex)
		Log.Debug($"Error stopping acquisition of {_sourceDevicePosition} camera: {ex.Message}");
When re-connected, TriggerStartStream() triggers a background task that processes this code:
private bool DoStart(CancellationToken stoppingToken)
	if (_device is null) { return false; }
	if (_grab) { return true; }
	_stoppingToken = stoppingToken;
	_timeConverter = new(_device.NodeMaps[NodeMapNames.Device]);
	if (_acquisitionThread is null || !_acquisitionThread.IsAlive)
		_grab = true;
		_acquisitionThread = new Thread(AcquireAndProcess)
			Priority = ThreadPriority.Highest,
		_acquisitionThread.Start();
		Log.Information($"{_sourceDevicePosition} camera: starting acquisition");
		return true;
	return false;
private void AcquireAndProcess()
	if (_device.Stream.IsRunning) { return; }
		_device.Stream.Start();
		while (_grab && !_stoppingToken.IsCancellationRequested)
				using var image = _device.Stream.WaitFor(_streamWaitTimeout, out var status);
				if (status == WaitStatus.Abort)
					_grab = false;
					break;
				else if (status == WaitStatus.Timeout)
					Log.Debug($"Camera wait timeout of {_streamWaitTimeout.TotalMilliseconds}ms reached");
					continue
				ProcessImage(image);
			catch (InvalidOperationException)
				_grab = false;
				Log.Debug($"Unknown exception in camera");
				_grab = false;
		Log.Error(ex, $"Failed to start camera stream");
		_grab = false;
Hello Michael,
The issue is a race in the stream lifecycle: Stop(), Start(), WaitFor(), and IsRunning can run concurrently on the same stream. A reconnect can schedule Start() while the preceding disconnect task is still stopping, or while the acquisition thread is still inside WaitFor().
ConnectionStateChanged should only signal the state change. Have one owner for all CVB stream calls, preferably the acquisition worker, and serialize this sequence:
  1. On disconnect: cancel the token passed to WaitFor; do not call Stop() from a separate task.
  2. Let the acquisition worker leave WaitFor (WaitStatus.Abort), then stop/clean up the stream there.
  3. On reconnect: wait until that worker has fully completed its stop, then start it once with a fresh cancellation token.
On disconnect, call cvbCancellationSource.Cancel(). The worker should check cancellation even if an image arrived, then perform its own Stop()/TryStop() before reporting that it has stopped. Only after that completion signal may the reconnect path create a new worker and call Start().
Here’s a small example:
using Stemmer.Cvb;
using Stemmer.Cvb.Driver;
using System.Threading;
private Device _device = null!;
private Thread _acquisitionThread = null!;
private readonly object _stateLock = new();
private readonly AutoResetEvent _connectionChanged = new(false);
private bool _running = true;
private bool _connected;
private CancellationTokenSource? _waitCancellation;
public void StartCamera()
    _device = DeviceFactory.Open(DeviceFactory.Discover().First());
    _connected = _device.ConnectionState == ConnectionState.Connected;
    _device.ConnectionStateChanged += ConnectionStateChanged;
    _acquisitionThread = new Thread(AcquireImages);
    lock (_stateLock)
        _connected = e.NewState == ConnectionState.Connected;
        // Only interrupt WaitFor. Do not call Stream.Stop or Stream.Start here.
        if (!_connected)
            _waitCancellation?.Cancel();
    _connectionChanged.Set();
private void AcquireImages()
    var stream = _device.Stream;
    while (_running)
        // Wait until the camera is connected.
        while (_running && !IsConnected())
            _connectionChanged.WaitOne(250);
        if (!_running)
            break;
        var cancellation = new CancellationTokenSource();
        lock (_stateLock)
            if (!_connected)
                continue;
            _waitCancellation = cancellation;
            stream.Start();
            while (_running && IsConnected())
                using var image = stream.WaitFor(
                    TimeSpan.FromSeconds(1),
                    cancellation.Token,
                    out var status);
                    break;
                    continue;
            Log.Error(ex, "Camera acquisition failed");
        finally
            lock (_stateLock)
                if (ReferenceEquals(_waitCancellation, cancellation))
                    _waitCancellation = null;
            // This is the only place that stops the stream.
            stream.TryStop();
private bool IsConnected()
    lock (_stateLock)
        return _connected;
public void StopCamera()
    _running = false;
    lock (_stateLock)
    _acquisitionThread.Join();
Cheers,
Tim
Than you for your detailed reply.
I initially wanted to implement the WaitFor() method (with the token param) as you suggest but it actually doesn’t exists in my C# API (only in your documentation !).
I only get these two overloads (using CVB v.15.00.004, Stemmer.Cvb.dll file version 2.10.1.18)
#region Assembly Stemmer.Cvb, Version=2.10.0.0, Culture=neutral, PublicKeyToken=xxx
// C:\MyProject\Components\ThirdParty\StemmerDllWin\Stemmer.Cvb.dll
// Decompiled with ICSharpCode.Decompiler 9.1.0.7988
#endregion
// Summary:
//     As Stemmer.Cvb.Driver.Stream.WaitFor(Stemmer.Cvb.Utilities.UsTimeSpan), but does
//     not throw on timeout.
// Parameters:
//   timeSpan:
//     Time span to wait for (millisecond granularity).
//   status:
//     Either Stemmer.Cvb.Driver.WaitStatus.Ok; Stemmer.Cvb.Driver.WaitStatus.Timeout
//     if timeSpan was exceeded; Stemmer.Cvb.Driver.WaitStatus.Abort if Stemmer.Cvb.Driver.Stream.Abort
//     or Stemmer.Cvb.Driver.Stream.TryAbort was successfully called.>
// Returns:
//     Acquired image if status is Stemmer.Cvb.Driver.WaitStatus.Ok.
// Remarks:
//     Still throws exceptions on other errors.
public virtual StreamImage WaitFor(UsTimeSpan timeSpan, out WaitStatus status) { ... }
// Summary:
//     Waits for the given timeSpan for the next acquired image.
// Parameters:
//   timeSpan:
// Returns:
//     Grabbed image.
// Exceptions:
//   T:System.TimeoutException:
//     Most common exception: timeSpan elapsed without receiving new image.
//   T:System.OperationCanceledException:
//     This operation has been aborted via Stemmer.Cvb.Driver.Stream.Abort or Stemmer.Cvb.Driver.Stream.TryAbort.
// Remarks:
//     Attention: it is generally not safe to call the wait method from different threads
//     on the same object!
//     Dispose the returned Stemmer.Cvb.Image when not needed anymore!
//     By default the returned image content is only guaranteed to stay unchanged until
//     the next call to this method; afterwards the returned image is normally disposed.
//     Thus it is normally not save to use this image in a display.
//     The returned image is not necessary the newest. If more images where acquired
//     since the last call to this method, the content is the oldest not collected image
//     buffer by default.
public virtual StreamImage WaitFor(UsTimeSpan timeSpan)
Therefore it’s why I triggered (from ConnectionStateChanged() ) a device.Stream.Stop()
Hello Michael,
it looks like you are using the outdated VIN acquisition stack. For a newly written modern acquisition I would suggest switching to the GenTL stack.
You can find a code example on how to use that in your local CVB installation:
%CVB%\Tutorial\Image Manager\Cvb.Net\SimpleStreamingGen3
This should also give you the correct overload.
Cheers,
Tim
Thank you Tim for your support. I really appreciate it.
I updated my implementation to run with the 3rd gen stack and now I can implement the WaitFor with the token parameter. It quite works well but I faced a strange behavior. The WaitStatus seems to be inverted (Abort ↔ Timeout). Here the part of code concerned (called in a loop):
private EAcquisitionResult ProcessNextAcquisition(
	ImageStream stream,
	IntegerNode? bufferCountNode,
	DaqValue daqValue,
	DaqValueItemImage daqValueImage,
	int loopNr,
	CancellationToken ct)
	using var image = stream.WaitFor(_streamWaitTimeout, ct, out WaitStatus status);
		return EAcquisitionResult.Aborted;
		Log.Debug($"Camera {_sourceDevicePosition} wait timeout of {_streamWaitTimeout.TotalMilliseconds}ms reached");
		return EAcquisitionResult.TimedOut;
	ImageProcessing(image);
When I disconnect the camera, the ConnectionStateChanged cancels the token. It should lead to the release of WaitFor with the WaitStatus.Abort state. But as you can see in my debug session it leads to WaitStatus.Timeout:
When I stop the hardware trigger of the camera, the token is not canceled and it should lead to the release of WaitFor with the WaitStatus.Timeout state (set to 15s). But as you can see in my debug session it leads to WaitStatus.Abort:
I would be surprised you inverted the actual status meaning of your API. It there something I miss ?
Hello Michael,
thank you for reporting, this actually is a bug in the C# wrapper.
I have already fixed this issue and it will be released with the next CVB version.
In the meantime, as a workaround you can temporarily treat Timeout as aborted and Abort as timed out.
Sorry for the trouble.
Does the reconnect work now that you have switched to the 3rd gen acquisition stack?
Best regards,
Tim
OK I’m waiting on the next fixed release.
But apart from that WaitStatus joke :wink: The connection handling is now fast and reliable. Thank you again for you support :+1:
