Device Discovery
Hi,
Sorry to hijack this thread, but I believe I ran into the same issue in the C++ SDK.
I can Snap ok after device discovery, but G2Wait results in a time-out (CVC_E_TIMEOUT).
Opening a camera through a .vin file works as expected, and does not produce the time-out on G2Wait.
Can you confirm that this is the same issue?
I tested this on a DALSA Genie Nano M1280 and a DALSA Linea LA-GC-04K05B.
(C++ code to reproduce the problem below.)
void Test_Camera_ok ()
    // Load the image
  IMG hCamera = nullptr;
  LoadImageFile ("C:\\Program Files\\STEMMER IMAGING\\Common Vision Blox\\Drivers\\GenICam.vin", hCamera);
  if (Snap (hCamera) == CVC_E_OK)
    std::cout << "Camera successfully snapped an image." << std::endl;
  G2Grab (hCamera);
  if (G2Wait (hCamera) == CVC_E_OK)
    std::cout << "Wait completed successfully." << std::endl;
  G2Freeze (hCamera, false);
  ReleaseObject (hCamera);
void Test_Camera_nok ()
  // Execute a simple discovery
  ATLIST discoverList = nullptr;
  DODiscover ("", DO_DISCOVER_FLAG_IGNORE_VINS, 0, discoverList, 0);
  // Retrieve the JASON ACCESS TOKEN for the first device
  size_t stringSize = 0;
  DOEntryGetInfo (discoverList, 0, DO_DISCOVER_INFO_ACCESS_TOKEN, NULL, stringSize);
  std::string accessPath (stringSize, '\0');
  DOEntryGetInfo (discoverList, 0, DO_DISCOVER_INFO_ACCESS_TOKEN, &accessPath[0], stringSize);
  // Load the image
  LoadImageFile (accessPath.c_str (), hCamera);
  ReleaseObject (discoverList);
  G2Grab (hCamera);
