Hello @Mikael
as far as I recall, C5 delivers multipart data. so you can access each of the parts with the following approach:
using namespace Cvb;
CompositePtr composite;
WaitStatus status;
NodeMapEnumerator nodeMaps;
std::tie(composite, status, nodeMaps) = stream->Wait();
for (int i = 0; i < composite->ItemCount(); i++)
auto component = composite->ItemAt(i);
if (auto image = get_if<ImagePtr>(&component))
// Process image
else if (auto pointCloud = get_if<PointCloudPtr>(&component))
// Process point cloud
or, you iterate through the parts if you know what they are:
WaitStatus status;
auto part = composite->ItemAt(0);
if (auto image = get_if<ImagePtr>(&part ))
// go on
if you started the device with AccessToken property “AttachChunk”, and did nothing else, (e.g. no manual set of ChunkModeActive node), the chunks are attached to the Device nodemap. There you find valid values for your current buffer.
Hello @Mikael ,
No worries: ‘Custom’ just means: not a single Image, not an ImageCube, not an Image List, not a composed MultiAoi image, not a rangemap, and not a pointcloud. This is true, as the buffer contains an image and a chunk.
AT and chunk should be possible. Although, there are CVB versions which needed a fix. What version do you use?
Could you write to this email with your exact CVB version, AT C5 version, your program, a log and your device nodemap settings.
