Working with 3D-Cameras of Automation Technology in CVB
Hi support team,
When I use this method, how can I get imgDC0, imgDC1 and imgDC2 pointer?
If using
Dim imageDataDC1 As LinearAccessData = imgDC1 .Planes(0).GetLinearAccess()
Dim basePtrDC1 As IntPtr = imageDataDC1.BasePtr
the error will occure at GetLinearAccess().
Thank you for your support.
Hi @Charlene,
What kind of error do you get? If it is an exception, the documentation might give you a hint:
FormatException If the plane’s pixels are not accessible linearly
System.ObjectDisposedException If Parent has already been disposed
InvalidOperationException Thrown if the size of T and DataType.BytesPerPixel are unequal.
If you get the LinearAccessData keep following in mind:
For Visual Basic .Net you need to use the helper functions provided in the System.Runtime.InteropServices.Marshal class for the increments.
Hi @Sebastian
When I use
Dim rect As New Rect(0, 1, img.Width - 1, img.Height - 1)
Image = img.Map(rect, Size)
Dim imageData As LinearAccessData = Image.Planes(0).GetLinearAccess() 'the error is at this line
Dim basePtr As IntPtr = imageData.BasePtr
it will show the error:
System.ArgumentException
HResult=0x80070057
Message=Operation Linear Access only supported on linear VPATs.
Source=Stemmer.Cvb
The problem should be the pixel is skipping. It is non-linear.
Can we use GetImageVPA() to get non-linear mapped image pointer?
Which function of CVB.Net can be used?
Thank you for your reply.
@Charlene
In the ImagePlane you can use the GetVPATAccess() function to access the VPAT access to the plane´s pixels.
Hi @Sebastian
Could you give me a example how to use GetVPATAccess()?
I am not familier with the code how to use GetVPATAccess().
I cannot find out CVB sample to use this function.
Thank you.
@Charlene
Hey!
Have a look at the little example below. This should explain how to access the VPAT Access Data.
var device = DeviceFactory.Open(@"%CVB%Drivers\GenICam.vin");
device.Stream.Start();
for(int i = 0; i < 10; i++)
    var image = device.Stream.Wait();
    var vpaAccessData = image.Planes[0].GetVPATAccess<byte>();
    Console.WriteLine(vpaAccessData[500, 500]);
device.Stream.Abort();
Furthermore, here is a link for the CVB Online Documentation
( https://help.commonvisionblox.com/NextGen/14.0/index.html ), or if more precisely needed the GetVPATAccess Method ( https://help.commonvisionblox.com/NextGen/14.0/cvbnet/d6/df0/struct_stemmer_1_1_cvb_1_1_image_plane.html#a988c5eddc936b27b3d91c776a8a22bab )
Thanks and regards
Silas
Hi @silas
Thanks for your promp answer.
How can I convert vpaAccessData to “IntPtr” data type so that I can convert CVB image format to other image format?
Yours sincerely
Charlene
@Charlene
Hey!
You can achieve that by simply using the VPAT from the image plane and getting the corresponding Base Pointer.
var vpat = image.Planes[0].Vpat;
IntPtr vpatPtr = vpat.BasePtr;
Regards
Silas
@Charlene
Hey!
I´ve come to a possible workaround regarding the VPAT Access. If you either copy or clone the image you´ll be able to do linear access on the copied/cloned image and avoid VPAT access.
Note that VPAT access is one of the slower access modes, so linear access is preferred.
var copiedImage = image.Copy();
var clonedImage = image.Clone();
Regards
Silas
@silas
Thanks.
It works now.
Yours sincerely
Charlene
