Sherlock CVB Driver Releases
#1
This is a closed topic which will be used to inform you about new Versions of the Sherlock CVB Driver.
I will create a new post with every new Version of the Sherlock CVB Driver
By using the Watching tag you will be notified if a new post was written by me.
With this you will be up to date if a new version was released.
If you have questions about a release please create a new topic.
closed #2
pinned #3
#4
The Sherlock CVB Driver 3.0.1 was released.
It can be downloaded on our websites and here:
ftp://ftp.imaging.de/forum/setups/thirdparty/Sherlock CVB Driver 3.0.1.zip
Release Notes:
  • Added: Writing of volatile Genicam Features like PacketSize,PacketDelay if the camera is reconnected.
  • Added: Added TriggerSource as INI-File parameter which is used if external camera trigger is configured in the application.
    This overrides the initial trigger source which is read out during start of the application.
    But the intial trigger source is still used to set it back to the initial value when the application is closed.
  • Added: TriggerSelector added to be able to use a nother TriggerSelector value than “FrameStart” if necessary
  • Added: Trace Log Output for Set/Get Gain and Set/Get Exposuretime in the Camera Class.
  • Bugfix: In handling the Triggermode and TriggerSource which could lead to a situation where
    After reconnect the TriggerMode and TriggerSource are reset to the value before the disconnect.
  • Bugfix: SetTrigger function in GenICam Object does not save the previous trigger state anymore
    so that the Trigger is set to the needed value in every case and it does not assume
    a previously set value which can lead to the wrong behavior.
  • Bugfix: Disconnect of camera which was detected changed the trigger source to software even if external camera trigger
    was activated and the grab was stopped.
  • Bugfix: After reconnect the TriggerMode and TriggerSource are reset to the value before the disconnect.
#5
The new Version 3.0.2 was released.
It can be downloaded here:
Sherlock CVB Driver 3.0.2.zip
Release Notes:
  • Fixes wrong reconnect handling.If a sherlock timeout occurred a reconnect of a disconnected camera was ignored.
#6
The new Version 3.0.4 is now released.
Sherlock CVB Driver 3.0.4.zip
Release Notes:
Fixed error which was introduced in version 3.0.0. It was not possible to use the DeviceTL Nodemap (e.g. Grabber Nodemap) from the driver if the Device Nodemap was not available.
Fixed error with manual software trigger which did not work after starting the application in some cases.
#7
The new version 3.0.6 is now released.
It is strongly recommended not using the 3.0.4 version due to a performance issue if using the AutoSoftwareTrigger. This is activated by default.
The new version can be downloaded here:
Sherlock CVB Driver 3.0.6.zip
Release Notes:
Since Version 3.0.4 the AutoSoftwareTrigger feature used a wrong internal acquisition status which resulted in repeating StopAcquisition and StartAcquisitions. This reduced the performance of the image acquisition significantly.
