When I check the return values from CVB functions it, seems that they sometimes succeed and still return FALSE
E.g.
if (<CVB Function> == TRUE)
// this does not happen even if CVB Function succeeds
After adding log messages to our code I see that not all CVB functions behave the same way. Some behave as excepted and evaluate to TRUE
in the above code, some others don’t. Is this a bug? Any ideas?
Hi @DeprecatedCoder,
I would strongly advise against comparisons that follow the pattern
if (foo() == TRUE)
because checking versus a specific value is contrary to the concept behind boolean values.
In Common Vision Blox those functions returning boolean values return a value of type cvbbool_t
which on the Windows platform is just a typedef for BOOL
which itself is also just a typedef for int
. One way or another the boolean types of programming languages always end up being mapped to integer types anyway…
Now functions returning a value of type BOOL
are expected to either return TRUE
or FALSE
depending on the outcome, and with MSVC these two values have been defined as (see e.g. wtypes.h)
#define TRUE 1
#define FALSE 0
For a function compiled with MSVC and following the convention to either return TRUE
or FALSE
your approach to check versus TRUE
would work well enough. Conceptually, however, the false case is to be associated with 0 and the true case with anything other than 0 and in fact a Delphi function with a signature like
Function foo() : LongBool;
returning True
will return -1 if I recall correctly, and this is where the comparison versus TRUE
will fail you.
Parts of Common Vision Blox have been implemented using Delphi compilers, and I assume you have run across one of these Delphi-based functions in your endeavors that causes your comparison to fail.
Luckily the solution is fairly easy:
Given a function
cvbbool_t foo();
Instead of writing
if (foo() == TRUE)
write
if (foo())
The latter will check successfully for any return value !=
0 and fail for ==
0 - exactly what you want in either case. This will make your code independent of the actual interpretation of TRUE
but still follow its meaning, regardless how a given version of any given programming language implements TRUE
