Do I understand correctly: You connect the camera directly to your NICs. So that if you disconnect the camera also the NIC becomes disconnected?
Does device configuration work with the GenICam Browser or the :cvb: Management Console?
Multiple NICs in the same subnet are considered non-standard by Windows.
This would happen if you attach a switch/router to both NICs and the camera to it. Then various problems occur like cameras not being able to be opened. If you attach the camera directly this won’t happen. If you attach two cameras to one NIC each you also would have the issue.
We will look into this after the Christmas Holidays (which last until 05 January 18).
