Hi again,
Just to update on this, I have now been able to get the USB cameras streaming as desired.
We took delivery of 2 GigE cameras, which after some trial and error setup for PTP acquisition worked with the example below:
import datetime
import cvb
import time
import os
NUM_ACQUIRES = 0
NUM_FAILS = 0
ARRAY_1 = []
ARRAY_2 = []
TIMES_1 = []
TIMES_2 = []
class MyStreamHandler(cvb.MultiStreamHandler):
def handle_async_wait_result(self, wait_result_list):
print("handle_async_wait_result start")
super().handle_async_wait_result(wait_result_list)
image1, status1 = wait_result_list[0]
image2, status2 = wait_result_list[1]
global NUM_ACQUIRES
global NUM_FAILS
global ARRAY_1
global TIMES_1
global ARRAY_2
global TIMES_2
if status1 == cvb.WaitStatus.Ok and status2 == cvb.WaitStatus.Ok:
NUM_ACQUIRES += 1
ARRAY_1.append(image1)
ARRAY_2.append(image2)
TIMES_1.append(image1.raw_timestamp)
TIMES_2.append(image2.raw_timestamp)
print("====================================================")
print("1 image: " + image1.__class__.__name__ + " " + str(image1) + " | Time: " + str(image1.raw_timestamp))
print("2 image: " + image2.__class__.__name__ + " " + str(image2) + " | Time: " + str(image2.raw_timestamp))
else:
NUM_FAILS += 1
device1 = cvb.DeviceFactory.open(os.path.join(cvb.install_path(), "drivers", "GenICam.vin"), port=2)
device2 = cvb.DeviceFactory.open(os.path.join(cvb.install_path(), "drivers", "GenICam.vin"), port=3)
print("devices")
stream1 = device1.stream()
stream2 = device2.stream()
print("streams")
stream1.ring_buffer.change_count(200, 0)
stream2.ring_buffer.change_count(200, 0)
print("Setup done")
with MyStreamHandler([stream1, stream2]) as handler:
print("pre-run")
start_time = datetime.datetime.now()
handler.run()
time.sleep(1)
handler.finish()
print("Took {} seconds".format(datetime.datetime.now() - start_time))
print(NUM_ACQUIRES)
print(NUM_FAILS)
I thought I’d try the USB cameras with the same changes made in the GenICam Browser, and they also worked.
The key parameters seemed to be setting Trigger Selector to Frame Start, and Trigger Mode to Off. We had Trigger Mode On from the examples that had been sent over previously.
Thanks,
Alex
