# CVB Python Multi-Camera Acquisition
**URL:** <https://forum.commonvisionblox.com/t/cvb-python-multi-camera-acquisition/1781>\
**Category:** Python API\
**Tags:** python\
**Created:** [August 30, 2022, 1:16pm UTC](https://forum.commonvisionblox.com/t/cvb-python-multi-camera-acquisition/1781 "2022-08-30T13:16:51Z")\
**Posts on this page:** 1\
**Showing post:** 14
<div class="post-metadata">
**Author:** ![kazunari](https://yyz1.discourse-cdn.com/flex027/user_avatar/forum.commonvisionblox.com/kazunari/32/601_2.png) [@kazunari](https://forum.commonvisionblox.com/u/kazunari)\
**Post date:** [September 7, 2022, 2:40am UTC](https://forum.commonvisionblox.com/t/cvb-python-multi-camera-acquisition/1781/14 "2022-09-07T02:40:08Z")
</div>
Hi Alex,
Thank you for the reply.
> We went through the settings in the GenICam Browser, and saved them as a user set on both of the configured devices.
Yes, that’s the procedure that I wanted to ask you. Thanks.
> The device on port 1 doesn’t run, either by itself or when tried with the device on port 0.
Could you show me the exact code, please? It’s not necessary to show the whole program but I would like to know the lines that give you the expected result.
> Can I install CVB 14 alongside 13?
Please forget about it because I do not want to mess this up; I just wanted to make sure you can reproduce the original issue on CVB 14.
Last but not least, I would recommend knowing the difference between Python threading and multiprocessing because you may find one works for a demo but it does not mean the concept works for your final application because the difference can be very critical; then you will need to go back and start developing it from scratch. (I recommend you check the script that I recently posted on [another post](https://forum.commonvisionblox.com/t/cvb-python-multi-camera-acquisition-software-trigger/1782/11).)
_[View the full topic](https://forum.commonvisionblox.com/t/cvb-python-multi-camera-acquisition/1781)._
